REZRCT
Hi Guys,
My name is Rocky, currently live in Auckland, New Zealand.
I own a 1995 EJ1 Civic Coupe Race Car:
Quick run down of mod's list, might have missed a few things.
1995 Honda Civic Coupe EJ1
Black
Engine:
B18C1 – 1800cc Dohc Vtec Motor
Wiring De-loomed
Full A/C and Heater system removed
Manual Steering Rack
Hondata S300J ECU
Innovative 85A Solid Engine Mounts
Solid Torque Mounts
Silicon Radiator Hoses
Buddyclub 4-2-1 Headers
Buddyclub Pro Spec Cat back Exhaust
Password JDM Thermal Intake Manifold Gasket
Password JDM Sump Baffle Plate
Skunk2 Pro Series Intake Manifold
Skunk2 Carbon Composite Fuel Rail
Spoon 70mm Throttle Body
Spoon Spark Plug Leads
NGK Iriway 8 Spark Plugs
P2R Racing Throttle Body Thermal Gasket
Tomei Fuel Pressure Regulator
AAP Fuel Pressure Gauge
Walbro Intake 190l/h Fuel Pump
CTR N1 Crank Pulley
DC2 Aluminium Radiator
Slim Radiator Fans
J’s Racing Thermostat
Buddyclub Fan Switch
J’s Racing Magnetic Sump Bolt
Simota Intake Pipe Heat Wrapped
Blox Velocity Stack and Filter
Odyssey PC680 Battery
Engine Bay Dress Up:
Password JDM fender Washers
Password JDM Aluminium Radiator Stay
Passowrd JDM Solenoid Cover
Skunk2 Reservoir Socks
Password JDM Carbon Spark Plug Cover
Custom Oil Cooler Set Up
Custom Oil Breather Set up
Moroso Race Sump
Spoon Sump Heat Sheild
Suspension/Handling/brakes:
Tein Flex Suspension
Buddyclub P1 Racing Front Camber Arms
Buddyclub P1 Racing Rear Camber Arms
Buddyclub Roll Centre Adjusters
Energy bushes front and rear lca’s
Password JDM Shifter Bushes
ITR 1 Inch Brake Master Cylinder and Booster
Cusco Brake Master Cylinder Stopper
ITR 96 Spec Front Sway Bar - Nolathane Links
ITR 96 Spec Rear Sway Bar - Custom Solid Endlinks
ASR rear sub frame brace
CTR Front and Rear Hub/Brake Conversion
EG6 Proportional Valve
Spoon Twin Block Front Callipers
Znoelli Slotted Brake Front Discs
Endless High Comp Front Brake Pads
Mugen Rear Slotted Brake Discs
Bendix Ultimate Rear Brake Pads
Goodridge Braided Brake Lines Front and Rear
Ultra Racing Front Upper 3 point brace
Ultra Racing Rear Upper 2 point brace
Ultra Racing Front Lower 2 point brace
Ultra Racing Fender Bars 3 point brace
8 Point Weld in Roll Cage built by SpeedFactor
Spoon Subframe Rigid Collars
Drive-train:
Y21 Gear Box Casing
OS Giken Close Ratio Gear Kit
OS Giken LSD
Gear X 4.9 Final Drive
Gear Speed Carbon Sychros
Gear Speed Hardened Sychro Hubs
Ogura Racing Hyper Single Clutch Kit with Chromoly Flywheel
ARP Flywheel Bolts
Interior:
EG6 SiR Cluster
Defi Oil Temp, Oil Pressure, Water Temp Gauges
Apexi RSM
Bride Carbon Kevlar Zeta III’s
Buddyclub Super Low Down Seat Rails
Silvester 4 point harness’s
Momo 350mm Steering Wheel
Momo Boss Kit
NRG Quick Release
Password JDM Carbon Fuel Pump Cover
Painted Saturn Black Interior
Painted Pink Roll Cage
Fastlane Extended Short Shifter
Buddyclub Type B Gear Knob
Sparco Window Net Drivers Side
Exterior:
RX7 Series 6 16x8 Wheels
Hankook Slicks
Buddyclub Aluminium Extended Wheel Nuts
WSX Front Lip
Speed Factory Carbon Fiber Bonnet
Speed Factory Carbon Fiber CSL Boot
SSP Brake Ducts
Roof Wing
AAP Orange Corner Indicator Housings
Password JDM rear Tow Hook
Dyno Tune: 147.3 kw at the Wheels
Have also added my build thread on here if anyone is interested: http://www.clubcivic.com/board/showthread.php?t=223158
And I also own a 1996 EJ7 Daily driver, won't post a pic yet. It needs abit of TLC.
Stumbled across this forum and thought I'd join up!
Black
Engine:
Wiring De-loomed
Hondata S300J ECU
Solid Torque Mounts
CTR N1 Crank Pulley
Slim Radiator Fans
Moroso Race Sump
Drive-train:
Y21 Gear Box Casing
OS Giken LSD
ARP Flywheel Bolts
Interior:
EG6 SiR Cluster
Apexi RSM
Momo Boss Kit
NRG Quick Release
Exterior:
Hankook Slicks
WSX Front Lip
SSP Brake Ducts
Roof Wing
