henna_yatsu
Hello again,
I daily drive my 98 civic dx with a d16y7 non v-tec. Whenever I start my car, it idles at 2k rpm (even if I leave it for 10 minutes it stays the same). Then, when I shift into 1st gear and hit the "hook up point" and begin to move, the idle falls to about 1.3k rpm. Then, when I shift to neutral, the idle goes to 2.3k rpm. After driving for about 15 minutes, the rpm dies down to a little under 1k.
Is this normal? I have heard that if it is cold then the engine does this to warm itself up. However, I live in Southern California and my car does this even when its hot outside.
I got the timing belt changed about 2000 miles ago and I changed my spark plugs at the same time. I don't remember if my car did this before the timing belt change or not.
I was told that the timing could be off but I wanted to make sure before I take it in to get it looked at. So if anyone with the same year and model civic can tell me if they have the same thing happen to them or not, I would really appreciate the help.
Thanks.
Thanks.
