is there a high/low headlight mod?
yellorado07
i know, search search, this is my only question and would appreciate any help
is there a way to get your low beams to stay on when you turn your highs on? on my chevy colorado it was just a jumper wire on the high/low relay. if there is already a thread, just let me know, thanks :-)
lethal6
Your Mom's Moderator
Your Colorado has 4 headlights. 2 high and 2 low. Civic only has 2.
lethal6
Ahhh. Yes, the 8th gen does have separate for the hi and low, my bad. You should have specified in your first post. I guess that is what I get for assuming.
Don't understand why, in a projector headlight, you would need to mod it for hi and low to be on at the same time. They are really bright as it is. I would also worry that the switch can't handle the extra juice running to it by having all of them on at once.
I've never done it so I can't help you there. Good luck.
yellorado07
I'm putting hids in 55 watt so will b on relays so no real strain to the switch. I just don't want the delay from switching between the two
