Is this a good deal for this '92 Civic VX - $1500
NandoKommando
I'm looking for a good commuter car so naturally I thought Honda Civic. I narrowed it down the the 5th Generation of Civics. I've done a little research, but thought it best to come here for some experienced advice. I've read that the Civic VX is generally the rare vehicle because their owners hold on to them as if they were gold. Their MPG is amazing so naturally I would love to get my hands on one. I found this one for $1500, but it has some problems, here's the description:
"The vehicle speed sensor is out so the speedometer doesn't work. The odometer reads close to 190k but with the speedo out I have no clue what the actual mileage is. There is substantial rust in both rear quarter panels, it's bad enough that it's probably not worth fixing. One of the rear seats will not fold down because the knob to do so is missing, might be able to just put a new one on, haven't checked into it. The trim on the exterior of the passenger door is loose and broken a bit. There is a check engine light sometimes when it goes into vtec. There is a little "blow by", (sends a little oil from the engine head into the air intake), goes through a quart of oil every 2-4 tanks of gas.
Now for the good, I have tracked every mile over the course of a few tanks with sprint gps, it is averaging 43 mpg on regular pump gas. It has an acura cd player. I replaced the head gasket when I bought it this summer. It does not need timing belt or water pump. It has a new valve cover gasket. It is a 5 speed."
Honestly cosmetics isn't too much of a concern at this point. I have heard that this generation of civics has a big problem with leaking oil. Is this a concern; is it easy/worth it to fix? I'm an EE Student so I'm pretty sure I can work around the Speedometer problem by making my own. I think its safe to say it has passed the 200K miles mark; this makes me a little nervous. Long story short, is this worth the price or will I need to put thousands more into this vehicle just to keep it going?
mymmeryloss
RHD is where its at
Offer them $500 and point out all of the stuff that is wrong with the car...
Shaaaft
FNG
If you had pictures of the car that show how bad the rust is that would help. If the quarters are completely rotted out and gone then I would stay away from it.
NandoKommando
Does anyone have any experience with En-Valve? It supposedly helps with the Blow-By.
MistahJuice
100% real juice
I'd pass on it man, loosing oil can be much more of a problem, especially if it isn't going to the ground. Rust is terrible too. Also with the speed sensor out the check engine light will be on and you don't know if it may have another CEL for a different reason as well. but if u none of that concerns you then just test drive and make sure axles arent popping and s**t
NandoKommando
Couldn't I just replace the Rear quater panels? I'll see if I can get some pictures tomorrow.
MistahJuice
100% real juice
Unless ur gonna do it all yourself or unless uve got the hookup, gettin new quarter panels welded in and then a repaint will cost you enough that you should have just gotten a better car in the first place. Not to mention the oil consumption and mileage
Aaron.
This, when they say no, offer 700. When they say no to that, give them your number and leave. They might call you in a few days and take you up on it
NandoKommando
I didn't realize the panels were that difficult. I think I'll pass on it, thanks for the advice.
Jose1027
You can find something better man,i got my 97 ex for 1500 nd it only had 98k miles
Sent from my LG-P999 using Tapatalk
