Is This A Myth Or Is It True?
edhgreatone
Is it true that if you put in premium gas that your car will run faster because it has high octane then unleaded gas. Also does premium gas actually get you better gas mileage or it just for certain cars?
Hesus
the LS PiMP
it is true, coz the higher is your octane the better the fuel burns in ya engine.
Bangin' HB
surfing member
not true. its a real long explain, but here are the cliff's notes: octane is fuel resistance to burn, lower octane=faster burn, high octane=slow burn. higher performance engines need higher octane to stock the fuel from igniting itself (predetonation) which pings, or knocks, and will damage an engine over time. our cars dont need this slow burn. i forget what magazine (no, not an import magazine) did a test, but they tested a variey of cars on the dyno to check output from octanes. one vehicle was a honda accord. well it actually made LESS horsepower when it was run on premium than it did on the regular which it was designed to run on. where-as the bmw made more power on premium b/c that is what it is designed for, it was knocking on regualar and the computer retarded timing to stop the knock.
Gwapz
What Type-R u?
dats tru, did dat wiv my first car..........starting knocking not very pleasant...........
anfrey
OG スバリスト
... i've always experienced worse mileage when i put premium in my car. . . so i just use regular all the time... i don't need more than 86 octane anyway. . . .
HybridTuner
Depends on your CR sence i have the b18c1 swap with a 10:1 ratio I "recommended by honda" must use 91+ octain in order not to have detonation.But as far as the d16 motors go I am sure the lower octain will be ok sence the CR's are a bit lower,but higher the octain the cleaner it burns and is healthier for your engine.Why do you think they sell 100+ octain at the track ?-because some car require it plus iff you put like 110 octain in your car at the track I promise your E.T. will be atleast a little better !and you can quote me on that !
anfrey
OG スバリスト
because several track cars require it. on my d16 i can run regular with no detonation. . .
HybridTuner
Did you actually read my whole post ?...see the part about the D16's ?-s**t people read !
anfrey
OG スバリスト
uhhh i did read, and i was backig up your statement. quit being so defensive. and maybe you should've used person rather than people since you were obviously referring to me, and nobody else. besides, you editted your post and added the extra stuff after the question mark after i posted. don't take me for an idiot.
Neon_ice
security at its finest
yea higher octane is so much better for your car, my dad told me that back in the day when they had like 110 at the gas station, there exhuasts wouldnt be black and sooty like they are today, they stayed realy clean due to it burning so much cleaner.
Bangin' HB
surfing member
but you gotta remember that older cars ran on leaded fuel, where modern cars run on unleaded. and an fyi, racing fuel is leaded. so most people think they are running better on VP, are really only hurting their valve seats and other components modernized to run unleaded. now premium gas is cleaner(forget where i read it, but it was tested and proven that some companies, mobil for sure, have injector cleaner in premium) but you also gotta realize that an engine not designed for premium will not run as good(and by good i mean mechanical wise, not how clean) take a car made to run on 87, put 100 in it, and under the right conditions, it wont start up as easy as it will on 87 (ive had lagging starts with as low as 94)
anfrey
OG スバリスト
chevron fuel has techron. . .
Beelzebubba
SubGenius Member
Wrong, partially anyway. Octane has nothing to do with how clean it burns and it is not necessarily better for your engine. Once again: Octane is an equation to measure gasoline's resistance to ignition from compression. Your car will run cleanest on the lowest octane tolerable by your engine with out any preignition. From experience, with 110 octane with 12:1 compression ratio in my Suzuki, the damn thing would hardly run. It was actually a lot faster on plain old 93 octane
civikskilz
for all the verbal pillage & technical chatter, has this man's question really been answered?
ImportRacerFF
Answer: Depends on the application. As Beelzebubba (or what ever his name) just said, its all about finding the lowest octane that can be burned with no knocking. High octane at the track is for the high compression turbo cars that require a high octane to stop knocking. (which is why many people say don't increase your compresion higher then 12:1 or else you have to get an octane not sold at gas pumps) This is also why their are turbo sparkplugs that you need to get. They give a lower temp spark allowing the fuel to burn w/ less chance of knocking (in effect allowing a lower octane fuel to be used).
In short, if your engine is does not knock don't get a higher octane.
Jas0n
What's up dogz!!!
that's nice info bro!!!!
duFf_M@N
...""peep show""...
Just use whatever you want and stick with it......I personally pump chevron 91 on my 98 EJ6. And it runs and starts great. And dont worry about the technical crap. Mine burns normally as it should.
