THE BLACK BOOT THINGY I COULDN'T PUT IT IN BECAUSE ALL THE WIRES AND OTHER s**t WAS TO BIG SO I JUST LEFT IT OPEN.
IS THAT A BAD THING TO DO?
i think water will not get to it plus i dont want it to be closer to the motor because of heat.Genuine Rolla said:Driver side one - might want to move that more in the engine bay so no water can get at it.
Passenger side - thats right where I have mine.
Also...could you post up some night wall shots of the HID's in your stock housing..? Thanks in advance...!
but the damn hole is small and my plugs will not fit though it.watisjdm said:get the black boot is a necessary thing
no u dont understand i do iave the rubber boot thingy but the problem on the rubber boot the hole is small so the HID plugs and wire cant go though them unless i cut the rubber boot alittle bigger.watisjdm said:there are rubber boots that go around the big hole and cover it up..get those asap
yes i do, they are rubber so i just stretched them over the plugs.immajackuup said:hay CHUNKY did u install the rubber boot to?
if show how the hell did u put the HID plug though it?
yea i just did the same thing with the rubber thingy and it does look more cleaner without seeing all the wires dangle.chunky said:yes i do, they are rubber so i just stretched them over the plugs.
and i'm not worried about water, i have fender liners so water doesn't even get to my filter
hay this Saturday i want to relocate my HID blaster but i don't know where to put it at.str8venom99 said:yea its a b***h to push everything though the boot but the headlight def needs that seal. spray a lil wd-40 on the boot and try sliding through
nah i cant do that because houston get some bad rain. so u don't know how to mount it under the head light?str8venom99 said:ive got mine monuted behind the bumper. passenger side is monuted to the side next to my cai filter and driverside is mounted in front of my washer fluid bottle. i know their not supposed to be in wet conditions but i didnt want them to be seen
