I must be getting old because its been a while since ive hooked up a sub and amp
the question is: was this the right combination sub/amp, i probably didn't get it rght.
Infinity REF1250W
300mm Single Voice Coil Subwoofer
Power Handling, RMS 300 Watts
Power Handling, Peak 1000 Watts
Sensitivity 93dB
Frequency Response 23Hz - 400Hz
Mounting Depth 5-1/16" (129mm)
Impedance 4 Ohms
WITH
Infinity 311a
mono D block amp
116 watts RMS x 1 at 4 ohms
(312 watts RMS x 1 at 2 ohms)
variable low-pass filter (32-320 Hz @ 12 dB/octave)
347 watt sdynamic power
freq. Response 17 hz - 302 hz
im guessing if the sub is single coil and 4 ohms that the amp will only be able to supply it with 116w at 4 ohms
i need a refresher, what to do
Infinity REF1250W
Sensitivity 93dB
Impedance 4 Ohms
WITH
Infinity 311a
mono D block amp
