JDM d15b water pump & belt
Robert lowman
I have a obd2 JDM d15b non VTEC with a y7 head. I know this cause I ran the numbers on block and head. What timing belt and water pump do I need? Its bout that milage and I can not find out
Mr.Baker
Mr. Search
You could Google it....but....
Use the belt that the head would use, so, a d16 timing belt will be what you need.
Robert lowman
Cool cool someone said a vx timing belt on google but that was for the obd1 VTEC engine. Mine is the d15b obd2 with y7 head. Dipstick by timing belt. Next issue it has the d15b7 obd1 intake and exhaust manifolds and distributor as well and I'm geting a check engine 8 code. Tdc sensor. Am I right in thinking it's the distributor? And the car runs fine until it warms up and it idles low and that's when the light comes on. If the engine is cold, the light is off. I'm using the p06 d15b7 ecu as all my engine controls are d15b7
Mr.Baker
Mr. Search
It could be a bad distributor, but, get a timing light, check the timing first.
