JDM D16A What ecu to use?
ugadawg187
I replaced my D16Y8 with a jdm D16A & wanted to know what the best ecu for it would be? The car is a 97 civic ex with a P2P ecu. Thanks for any advice!
johnmota93
Hey sorry i know it wont help cuz i dont have the answer to your question but i have a problem right now maybe you can help me.
I swapped my engine a little bit ago and have been trying to get rid of my c.e.l codes so i can use v-tec its my first car and i never got to use v-tec lol
I have a 1997 civic ex 4 door so i ordered a d16y8 long block which is the stock one for it but they brought me a d16A block and a y8 head i have v-tec and everything wired but i have a loose sensor thats not connected right under my Intake Manifold have no idea where it connects..
so i checked my codes and i have 2 c.e.l codes p0141 which is o2 sensor sensor 2 and the other one is P0325 which is the knock sensor so i checked where it goes on my 97 civic and its right next to oil filter a little higher to the left if your looking at it from under the car, problem is 97 civic comes with d16y7ory8 since my block is d16a and the sensor is on the block i dont see it im going to take off the oill filter but i tried feeloing around there and its just like a bolt screwed in but or the block but i dont feel the sensor to plug the loose one sensor into .
I have a p2p ecu also and wanted to know if your check engine light is on if its off did you get to connect the knock sensor or did you chip the ecu ? please help im going crazy over this loose sensor and c.e.l thanks man
