Just got a new steering wheel!
EatingYourBrainsY0
Team Sin Motorsports
Sorry not trying to post whore!! ;)
yea so i just installed my new steering wheel. MoMO 28oMM Team Black.....here are some pics.
Import_Girl
AKA Mz Honda
it looks nice how does it feel when u drive?
EatingYourBrainsY0
its very small and i have to get used to it. but worth the money and i like a lot
Blowncivic1320
how are u gonna pass inspection without an airbag?
gabebauman
Sk8aholic
Momo Wheel
Wow...280mm...and I thought my 320mm monte carlo was small. I just got it about 3 weeks ago. I was close to getting that same wheel too. NICE.
dannivti
hmm i love those steering wheels really cool but i don´t want to take my airbags out i pefer safety over looks but that steering wheel rocks :D
gabebauman
Sk8aholic
It's not just for looks.
krayziejcs
true
EatingYourBrainsY0
a lot of my friends have this one, thats why i didnt get it. but i like it a lot.
J Rod
JDM Like Whoa!!!
i miss my momo so much. Oh well. Theres always another time to upgrade..
You need ctr cluster =)
gabebauman
Sk8aholic
Did you get your horn hooked up? If not, I have something that should help.
EatingYourBrainsY0
no actually i was going to do that this weekend, just didnt have time last nite....is there something special i need?
gabebauman
Sk8aholic
Here is the approach I'll be using: http://www.honda-tech.com/zerothread?id=273474
http://community.webshots.com/album/49459198Cjsfnx (pics 11-15)
How to make the horn work:
Here is the most valuable piece of information that most people want to know… how to make the horn work when using the JDM non-SRS steering wheel from an EG.
1. Start off by getting a piece known as a shoe horn, PART #35259-SH3-A02, from any Honda dealer. It comes from the horn trigger of the 88-91 civics. It will look like this. PIC 11.
2. Some modification will need to be done to it in order for it to work properly. You will need to cut a tiny piece of the shoe horn in order for it to install correctly. The Red shapes in the pic are the things that will need to be cut. PIC 11.
3. Installation of the Shoe horn: Once you have gotten the modifications done to the shoe horn, proceed by unscrewing the combination switch lever which is held on by 3 screws behind the white plastic in the middle. You can see 1 of the screws here. PIC 12. Remove it carefully from the steering column.
4. Now, look on the bottom of the combination switch lever on the side with where you turn on the headlights. To connect the shoe horn, simply place the female spade connecter into the male spade connecter on the bottom side of the combination switch lever. Here is a pic from the bottom of the combination switch lever. PIC 13. Once that is secure, go back to the front and screw in the tiny screw that I said you needed too (it is silver on mine). PIC 12.
5. Wiring the horn. Now that the shoe horn is in place, you will need to wire it properly. Look behind the combination switch lever, (headlight lever side) and look and the wire connection area. Get about 2-3 feet of the 14-16 gauge wire for this. You will need to place one end of the wire where I have placed my hand holding it at in this pic. PIC 14.
6. The other end of the wire, will go where you previously separated the SRS wire harness from the underside of the steering column. I don’t know how to describe where to put it correctly, so I will just show you a pic of where to place it. PIC 15. Sitting from the driver seat, it should be on the left side of the connection.
7. That’s it for the wiring. Now place the combination switch lever back on the steering column, and put the 3 screws back in so that it looks like PIC 12 again.
Unless You were gonna use a different method...in that case fill me in. I haven't purchased the shoehorn piece from Honda yet.
