Amazing what the internet can do for you. A K swap can be really expensive if you try to get more out of it. A B swap would be expensive too if it was swapped with unnecessarily fancy parts. This list and budget swap is a very low end k swap, but a K swap nonetheless that will at least give you some potential later on. With your lack of knowledge and ease of budget, I would suggest a replacement D series or B series swap.....and search how to do it....
2004 Honda Accord K24A4 engine
2004 Honda Accord 5-speed transmission
2005 Honda Accord ECU for manual transmission
KTuner reflash
2004 Honda Element engine wiring harness for manual transmission
Hasport ECU sub harness
Hasport EGK4 mount kit
Hasport axles for K-swap
DC Sports K-swap header
2006 Civic Si intermediate shaft
2004 Honda Accord alternator
RSX idler pulley
serpentine belt
AEM fuel pressure regulator
2004 Accord flywheel
2004 Accord clutch
parts for intake and air filter
upper radiator hose
lower radiator hose
heater hoses
Rywire knock sensor connector
other misc wire and connectors
IAS
clutch slave cylinder and lines
2005 Honda Accord shifter and cables
02 sensor
brake line for clutch master
Hasport radiator hose adapter
fuel fittings and hose
