K Pro
Silver Bullet
6 spd = titis
ok first off i dont drive a civic anymore i drive a 05 rsx type s
im posting here instead of CI because it wont let me make a thread there and hopefully this thread will benefit me and the k series owners
ive been doing some research but i cant really find the answer im looking for my question is..
if i reflash my ecu (hondata) this is what im suppose to get
Features
VTEC window from 4900 to 5800 rpm
8600 rpm Rev limit, increased from 8300 rpm
Maximum torque gain 12 ft/lbs torque at 6000 rpm
Maximum power gain 20 hp at 8000 rpm
Peak torque increases by 6 ft-lbs
Peak power increases by 8 hp
Very wide flat smooth torque curve. 90% of peak torque available from 2200-8000 rpm.
Fully dealer compatible - works with all Honda scan tools and equipment
and if i k pro
Features:
Mounts in stock location and plugs into stock wiring harness.
Retains full immobilizer functionality to protect your vehicle from theft.
High speed USB connection
Re-calibrate for larger injectors.
3 dimensional tables for full i-VTEC mapping.
Compatible with OBDII diagnostic tools & smog station scan tools.
Datalogging of 40 major sensors.
User programmable fuel, ignition & cam angle tables.
Control of open / closed loop operation.
VTEC window control.
Multiple fuel & ignition tables for different intake cam angles.
Expanded tables for up to 11 lbs boost (even more with a 3-bar MAP sensor).
Nitrous control with activation window control, solenoid output control and fuel/ignition parameters.
so with k pro can i basically have my car tuned to the same power as the reflash and have the ability to turbo my car because if u just reflash ur ecu u still have to k pro it to run boost, nos, sc
im still researching as im posting this just curious if anyone is going thru the same thing
--<EM1>--
boosted ftw
did you mean to put this in EFI tuning?
LithG
Hey Bud don't forget that since you have a 2005 RSX that you'll need to get a 02-04 ECU and have that k-pro'd and get a special adapter for it.
Check out the link below for more info.
http://www.hondata.com/kpro0506.html
We are authorized dealers for Hondata, so let me know when you are ready to order and I can hook you up with member pricing.
Iggy
Silver Bullet
6 spd = titis
yea bro i did my research
i need a 02-04 ecu
the harness
an 02 oxygen sensor
and ah than have it k prod
since u k pro
can u tell me more about both?
and how much for all that i listed?
franklin-hid
your moms boyfriend
bump cuz i have kpro
i made 216WHp with only intake ,header
if u get k pro u car will make the 200wheel instead of 200crank which=170ishwheel
launch control is AMAZING
lowering vtec=teh sex
im FULLY tuned on kpro making 216 with vtec at 4500rpm's and rev limit set at 9k...
also
this is my old setup
new one coming soon :lol:
wen u do upgrade defff let me know. We(eastcoast) have one of the BEST "k-series" tuners out. They call him "yosolo". He is a MONSTER at tuning. He is right here in NJ so not too far from you
Any questions u have in mind?
i done tons of homoewrok
Silver Bullet
6 spd = titis
I've seen people from new jersey come to pa with a yosolo decal, but im on my sidekick right now I have tons of questions, but how much does he charge to tune the car, and what's ur new setup gonna be?
