K-Series Parts
RSX Base Throttle Body w/ IACV & TPS Sensors Only... $40
RSX-S Alternator...$60
RSX-S Throttle Cable... $20
RSX-S A/C Bracket... $10
RSX-S Transmission Mount Bracket... $10
RSX-S Front Sway Bar... $50 Shipped
EP3 Tie Rods.. $40 Shipped
RSX-S Slave Cylinder... $20 Shipped
TSX Slave Cylinder... $20 Shipped
TSX 6spd ECU... $120
TSX 6spd Transmisson.. 66k miles MINT.. $550 Local Pick Up ONLY
TSX PS Pump... $40
TSX 6Spd Flywheel & Pressure Plate + bolts... $60
TSX Charge Harness... $20
TSX 2005 Throttle Body... $50
TSX 6spd Axles... $70 for the set
EP3 EPS
I got a complete EPS setup from a 04 EP3.. Comes with PS Rack, Tie Rods, Mounting Brackets, Wire Harness and Module
Asking $500 shipped anywhere within the US.. Will ship International PM me for price
Located in Orlando.. Local pick is fine at a reduced price BUT will vary depending on the miles i have to travel to meet up.
For those who don't know what this is.. Its a Electronic Power System from the EP3. If you have a em2, es1, rsx-b or rsx-s with a K-Swap and what to retain your power steering this is what you would use.. Looks good and eliminates the power hose and pump, mainly used by people with shaved and tucked engine bays
2002 EM2 LX Parts
LX D17a1 Long Block(Non-Vtec)... $150
- 120k Miles
- Timing & Waterpump changed with 7k miles ago
- Only issue, needs a valve adjustment & Valve Cover Gasket
LX D17a1 Engine Harness (Non-Vtec)... $50
Alternator... $50
Power Steering Pump... $40
LX 5spd ECU... $50
5spd Starter... $40
Stock Exhaust. . . $50
Rear Lights. . . $60
Axles.. $60 both
D17a1 Complete Intake Manifold.. $60
D17a1 5spd Shifter Cables - $20
D17a1 Brake Booster - $40
High Pressure Power Steering Hose - $20
![](http://i1234.photobucket.com/albums/ff419/tetfemal/c05fc1d3.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/7b60fd68.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/a17b2a0b.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/117dabd6.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/eb053cf0.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/40a5e6af.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/1ab8dee5.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/b170d3eb.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/32b6a50b.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/51ca3a43.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/94629d06.jpg)
TSX PS Pump... $40
![](http://i1234.photobucket.com/albums/ff419/tetfemal/7cf2f4bb.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/d552b556.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/69e22733.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/b3d4adc0.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/566058c2.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/6c064f76.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/597dc9a9.jpg)
![](http://i1234.photobucket.com/albums/ff419/tetfemal/5e1d7bda.jpg)
EP3 EPS
![](http://i1234.photobucket.com/albums/ff419/tetfemal/5c79abd9.jpg)
2002 EM2 LX Parts
- 120k Miles
Alternator... $50
LX 5spd ECU... $50
5spd Starter... $40
Axles.. $60 both
