twrex22
Hey guys hope I can get some help with my demon car (1997 civic hx 5 speed)A month ago I noticed my battery leaking from over heating . So I decided it was just old and replaced it with a new one.problem stayed the same battery heating up . So I went to get a new alternator (not installed ). While driving to work my car dies I hear a poof and smoke coming out of my gauge cluster . I tow the car home try to turn it on it cranks but no go I check fuses notice the em fi fuse under the hood is blown I try to turn it on again instantly blows . So I go through every possible fuse find out 13 and 31 are blown and back up radio I replace them all. i remove the main relay.turn the key it DOESNOT BLOW EMFI FUSE#44 under the hood and begin looking for a short in the main relay connection
I checked every ground ... so my guess now is the white with black stripe.I'm so lost at this point. I'm wanting to just set fire to it
So what I know :
-car cranks over
-replaced fuse 13, 31, 44
-fuse#44 blows on ig2 right away
- if I remove main relay fuse doesn't blow in any ignition position
- I unplugged ecu, main relay , injectors and ivac to test with ohm reader
-#5 on main relay plug shows infinity on ig2
-#7 0n main relay plug shows infinty on all position
-all my fuses are new***
So what I know :
-car cranks over
