ok set up is D16Y7 1996 hatch
vitara set up.
eagle rods
gasket matched head
delta cam
MSD 6AL
MSD wires
MSD Blaster 2 coil
TD04 turbo
Greddy Emanage tuned by Jotech
ok i keep getting a miss fire codes on cylinder 1, 2, 3, 4,
do you think my timing could be off thats whats causing it, i had to replace the distrubitor cause it burned out on me put OEM back in work great, i change my plugs every oil change and they look good not white car is running at about 10.6 AFR using wideband O2 but EGT's are a little on the hot side
any suggestions
thank in advance
m
vitara set up.
eagle rods
gasket matched head
delta cam
MSD 6AL
MSD wires
MSD Blaster 2 coil
TD04 turbo
any suggestions
thank in advance
m
