keyless entry Help
NMDX00
so I just git a 2000 cuvic dx it came with a remote and had power lock switch on driver door but it does not work. .. please help. It does have an aftermarket headunit...
Posted from Clubcivic.com App for Android
EJackBauer8
Did you check the battery on the key fob?
NMDX00
yes battery is good. all fuses are good. not even the switch on the door works? is this because it does not have the factory radio in it?
DTvn
Yeah you need to wire in your factory radio.
I'm assuming your dome light doesn't react to the door either right?
NMDX00
dome light works just fine. can not hear acuater make any nose. so any ideas where I can get a replacement factory head unit? and how to wire both? I do not have the factory one car came with aftermarket
99ebpem1
With it being a dx, are u sure it even has power locks? Or did the previous owner just put a door panel on it from a car with power options?
Take off the door panel and see if he switch is hooked up. If not, see if there is a plug on the door harness. Im guessing there most likely wont be since the dx didnt come factory with power options.
NMDX00
that may be the case. lol. ill look at it later today and let you all know. thanks for the insight
NMDX00
there is a wireloom going from inside fenderwell through door jam into door on both the driver and passenger doors
99ebpem1
Yes, there will be. That will include your speaker wire. As well as for power windows and locks. But it is much smaller on cars with manual windows and locks.
If you remove the screw that holds the door lock to the door panel, it will come off. Then if there is not a plug from the door wiring harness that connects to the power door lock switch, then u either dont have power locks, or it is somewhere inside the door, if its there plug it up.
