Kill Switch Kill Car
BigEars2303
Well I put a kill switch in my 93 Civic SI, Right behind the lighter in the center console. Well had it in there for less then a day and went to go show my girlfriend it, cause she drives it to, while driving the car and I think the metal from the switch and the center console support, and killed the car. The car just shut off. Wouldn't start again. SO i needed a tow. Check engine light is on and won't jump to check code and stays solid. I think I killed the fuel pump. Not sure what else. Other then the fact that I am a big dummy, moron, or whatever you want to call me I need a checklist of what I need to look at for this repair. Starting from the simples things ( fuses, relays) to the bigger thing ( fuel Pump, engine). My only excuss was it was a rush job. Lesson learned, just need help please
anekin007
Unregistered User
what actually happen..im a little confused.. someone hit the switch while driving?..i wasnt really a fan of the kill switch.. i got a relay hooked on my fuel pump wire. i think is better then the switch. cost me less then $5, easier to install and less hassle then a kill switch.
BigEars2303
well i was driving, bumpped the console (where my kill switch was hidden), car was on, not moving at a light, and the car just died. wouldn't start at all. Car will not turn over. I think the back of the switch hit the metal center console support and fried the fuel pump. Or something, I just need to know what to look at to repair this, wheather it be fuses or relays, or a fuel pump, or whatelse would fix this. I want my car to start, I hate driving my GF stupid Ford Focus ZX3, wanna be hatch
krayziejcs
check the wires connected to the switch?
that happened to me 1 time but it was on a gas station i had to tighten the wires that were connected to the switch and it worked perfectly fine after that
btw isnt the body style of the zx3 a hatch also?
BigEars2303
well i check the wires and plugged them in to the orginal wire, just took out the switch. so everything is the was it was before the kill switch, still will not start. yes a zx3 is a hatch but it so damn ugly
BigEars2303
is there anything i can check, i am not sure, checked in my manuel, only thing i can think is the fuel pump is burned out. that's it. can you burn out your fuel pump like that?
anekin007
Unregistered User
you can use a digital multi meter and test the end of the wire where the fuel pump is to see it your getting power to the fuel pump.. but im not sure how to check the fuel pump to see if its fine or not..
x007den
New User
check and double check the fuse.
Tom
honda.co.jp
do this, i had this happen with mt boosted hatch, and i kept blowing the starter fuse over and over.
Tom
honda.co.jp
lol, always something so simple.
