Koni Yellow Settings
Danno
I am getting a set of Koni Yellows installed on my 99 coupe. I'm wondering what kind of settings people are running? Do you need to run them at the same firmness for all four or can you mix and match the setting. Do you need to run both fronts the same and both rears the same. Also, what setting is close to stock assuming 1 is the softest setting and 5 being the firmest.
Thanks
munky
run the front two the same and the back two the same.... just mess with the settings to see how you like it best.. decide whether you're going for ride quality, or performance quality
[civic]
Moderfucker
You can mix and match from the front and the back. Its really up to you based on how comfortable the ride is. I have the illumina set on 2 for the front and 3 for the rear.
Stiffer is better in some cases but is really uncomfortable on the streets of daily driving. Level 1 should be close to stock but could be a little stiffer than stock.
Play with the settings and eventually you will find the best one like I did.
