is there a way to use the stock cluster dimmer to dim leds
jacked_77 New Member 5+ Year Member Apr 26, 2008 #1 is there a way to use the stock cluster dimmer to dim leds
Zaiber New Member 5+ Year Member May 11, 2008 #2 I've heard you can if you use the same size bulbs in the cluster as LEDs.
Genuine Rolla Its PETEY PETE, y0! Registered VIP Registered OG 5+ Year Member 10+ Year Member 15+ Year Member May 11, 2008 #3 nope, doesn't work. I had them and you can't dim them at all.
