I installed amber LED rear turn signal bulbs (7440) since I tinted my tail lights red & want to keep the indicators looking amber. Of course, theyre flashing quickly now. Ive done some research and apparently its better to change the Turn Signal Relay, for the sake of reducing power consumption, instead of installing load resistors, which will still draw the same current as standard bulbs. If this is true, someone please advise what relay I should use. Also, is the reduction in power consumption significant enough to justify the relay over the resistors?
If I do install resistors, what would be the best wire location to install them for the EK coupe rear indicators?
