williammw20
Is the shift linkage supposed to be loose or nah? It's a stock d16y8 1.6 sohc
This. You can tighten the shifter on the linkage too, but if it loosens again that's a sign of worn bushings. At one point mine got so sloppy I couldn't even shift lolIf your shifter feels "sloppy" or loose, you might need to replace your shifter bushings. It's relatively cheap and easy to do.
Yeah it's the shifter, not the linkage. I would try tightening it up. If it loosens again, replace the shifter bushings.Thanks guys, my shifter has to much play in it lol I'll be driving let out of the gas & it'll move back& forth a little bit & when it's in gear I can move it at least an 1 1/2 to the left & right
That might be a sign of worn out tranny mounts also. But I'd first replace the bushing first to see if it solves your issue.I'll be driving let out of the gas & it'll move back& forth a little bit
That's just normal neutral play. Put it in a gear and post another video.00 civic ex 1.6l in 5th gear cruising figured I'd show how loose my shifter was & how much play it has. That's too loose right?
