troutman
Hi,
My 1996 Civic EX won't idle properly. In the AM (a cold start), it stalls. Once it is warmed up, it idles too high (1500- 2000 rpm's). I have replaed the cap, rotor, wires, plugs, IAC valve. I tested the Thermo Control Valve and am getting the proper voltage. I bled the coolant system after replacing the IAC. I need to test the IAC voltage: Is it 12 volts for the yellow and red wires?
I am open to any suggestions to fix this problem.
Thanks--
Thanks--
