LS turbo stall
94eg02wrx
Helloo.... I have a B18 turbo and I have noticed when at idle... It likes the try to cut out... Like someone has just stopped giving it fuel for a split second... And sometimes it does cut off? Any ideas?
Esotericimage
Taking an H-T break
What are you tuned on?
what is your fuel pressure at?
did u upgrade your fuel system?
have you cleaned you IAVC?
Do you change plugs every 3-5k?
Do you do Tune ups on a regular basis? rotor, cap, wires, etc?
have you cleaned the inside of the engine with injector cleaner or SeaFoam to remove carbon build up?
these would all be possible causes..
94eg02wrx
i am tuned with crome, no i did not upgrade the fuel system exept for an fmu ( which i hate i bought the car with it but am soon taking it off),and no i havent cleaned the iavc YET, haha , brand new plugs, rotor coil cap and wires are all new, and no i havent cleaned the engine with sea foam YET :shock:
hardcore97
Hard Core
so your running stock injectors?
2slo4u
wait4me
your tuned and your still using a fmu?
19dmann90
try geting a walbro 255 fuel pump and switch the injectors to something bigger maybe 450cc that should help it.... what is ur fuel pressure set at??
Esotericimage
Taking an H-T break
could be tuning and/or timing... i would recommend 440's or higher, an adjustable FPR and new fuel pump like stated above and reliable TUNE!
