Main Relay
irbryanxp
Does anyone have a diagram on how to replace the main relay in a 1988 honda civic dx. I'm almost positive thats the problem because I'm getting a code 16.
Unplug and remove the main relay. You can resolder rather than replace it to save money.
irbryanxp
so does that mean that I won't have to unscrew anything? I can just unplug it? And yeah I'll probably end up re-soldering it because the cheapest replacement I was was $53.
cfdff90
James
I Need Help!!!!
I have a 91 civic hatchback and i just replaced piston rings... however i got the whole car put back together and no it wont even try to turn over.. so i went to the first problem..power to the starter.. i had power from the battery but wasnt responding... where is the starter relay located in my car???
Check the starter switch located at the top of the clutch pedal. Unplug the connector and jump the two terminals with a jumper wire. If the starter now cranks the engine, then replace the switch.
cfdff90
James
thank you.. i took the starter and solenoid out of the car.. the solenoid wont go back together completely.. the pins in the solenoid cap will push in when you push them but the actual contact thing( with the gear and bearing) wont go in when you push it in...
cfdff90
James
is there an easier way to get to it other than under the dashboard?? like going from the steering column???
