the greddy kit is a/c compatible....... if you're building your own, pretty much any manifold that has the wastegate mounted on an extension pipe will work with your a/c......... i don't recommend this, though.... any lag is bad lag, and having the wastegate farther from the turbo is not a good thing. if you're serious about power then do it right and pull the a/c system
