ekhatchback
I got a 96 hatch. With none power windows. I'm not really sure. What I should do.. should I just replace the whole door.. the problem is the window keeps coming of track. I've adjusted the left and right side.. sprayed the traxs with lube hinges everything.. the window seals are bad.. the window is hard to roll up and down. Should it replace the whole door or replace tracks and seals..
