Manual window wont roll up all the way. Frustrating... -_-"
Dnguyen92
I can't roll my window up all the way. I'll crank it and it'll stop cranking til i have like about a 1/2 in - 1 inch left. So I got about a 1 inch opening. Rainy season is coming soon so I would love to just be able to close that mther fcker. I've tried emptying a whole bottle of WD40 and still nothing. Any tips?
R3dline
my mazda was doin this friday, check the rubber track your window sits in, mine was bunched up , unbunch it, and grease it, should be golden, take your door panel off tho and see what its getting snagged on.
Dnguyen92
hmmm rubber track? All I see is like an X-like bar that it screwed onto. A picture would help! maybe i'll just take a picture and you can point it out for me.
97ek_coupe
dont use wd40, go get some silicon spray, eks are known for their window problems.
LiveEj6
In red is where the rubber guides/seals are. to readjust, there are two 10mm bolts at the bottom of each side of the seal. remove them to slide the glass back in. be careful not to break your window, it might be tricky to put the glass back in the rubber guide.
pinoiballa14
Deretsiger Resu
idk if its too late to post buy i had this problem last year. window fell out of its track. you hav to remove ur door pannels to get to the bottom of the track. and then take a couple of washers to get the track straight. then put some silicon lube along the track
