CanyonCoolMan
I need to know If there is an easy way to adjust or replace the clutch. And if that's not possible how much do you think it will cost?
Here is a nice long story about what happened
So I was driving around in the snow just practicing and I had the heater running. After about 5 minutes this horrible smell started to fill the car. So I just opened the door and let it air out for a minute and turned off the heater and kept going. After about 30 minutes I wanted to go driving some where else and not on a loop so I went around and started noticing the smell without the heater running and having to release the clutch farther to get the car moving. I decided to start heading back. This kept getting worse and worse. As I was going up the final hill I had to add about 5k RPM just to keep the car at about 5mph with the clutch all the way out. My grandpa took over and managed to get it part in the drive way where it finally died. R.I.P.
Sent from my SM-G900V using Tapatalk
