I've owned this car for almost a year now and thought I'd share it with you guys. Granted I did buy this car from Macspeed Motorsports so the credit for the actual motor swap and cosmetic goes to them. However when I did buy it it was running like garbage, so I've had to change up quite a bit on it. Any who onto the build list.
1993 civic hatchback dx
1996 civic front end conversion
Oem ek radiator support
Modified Oem eg fenders
Shift sports carbon fiber hood
Blue ion headlamps
Abs canards
Red/clear tail lamps
Thin side moldings
Megan racing duckbill spoiler
Modified Oem eg rear bumper
Modified Oem eg front bumper
Gloss black roof
Carbon fiber rear hatch
Midori green repaint
Type R style front lip
New rack/pinion boot
New intake manifold gasket
01 Honda accord f23 engine
ARP head studs
Oem Honda head gasket (new)
Skunk2 adj cam gear
Dsm 440cc injectors
Precision FMIC
Cx racing turbo charger .48
Log style turbo manifold (cast)
Tial wastegate
Greddy RS BOV
Walbro 195 fuel pump
Civic non vtec obd1 distributor
Slim fan (modified)
Modified radiator hoses
F22b intake manifold
EGR delete plate
93 Honda accord dx transmission
Cx racing h22 lightened flywheel
Stage 2 comp clutch
Mandrel bent exhaust
97 Honda accord shifter box
Moroso breather tank
Inline fuel filter setup
Steel braided fuel lines
An fuel fittings
Oem fuel filter delete
GREX oil filter relocation kit
Integra DA Oem axles
Yonaka motorsports engine mounts
Oem civic eg radiator
Tuned with hondata s300
Intercooler hard piping
Custom dump tube
Matte black valve cover
Matte black turbo parts
Refinished silver engine block
Autometer tachometer
Autometer oil pressure gauge
Autometer boost gauge
Innovate wideband
Braille style racing battery
NRG limited edition steering wheel
Hkb steering hub
NRG limited edition quick release
Gold Blox shift knob
Corbeau Forza2 racing seat
Oem black carpet
Oem eg door panels
Custom air bag dash delete tray
Deleted unneeded wiring
HVAC ac and heat delete
Audio system delete
Rear interior delete
Civic type Rx pedal assembly
Shifter extension
Willians 4pt harness
Roll bar padding
Civic dx gauge cluster
Blox Coilovers (drag spec)
Skunk2 front camber kit
Skunk2 rear camber kit
Bolt in roll cage (gold)
CPillar bar (gold)
Front strut tower bar (black)
Rear strut tower bar (gold)
15x8" xxr 002 0 offset (front)
15x7 xxr 002 +38 offset (rear)
Federal 595 195/45/15
Vms extended neo chrome lug nuts
Integra rear disc brakes
Powerslot rotors
Hawk hp+ brake pads
SS brake lines
BWR billet lower control arms (green)
BWR rear sub frame brace (green)
BWR billet rear lower tie bar (green)
10mm wheel adapters (rear)
Extended studs (rear)
230whp
230 tq
6 psi
It's still a work in progress, currently it's on jack stands, ill be dropping the trans sometime in the next week or 2 to replace the throwout bearing and inspect the main shaft bearings.
Hoping when I get this thing mechanically sound I can afford some better wheels. Ill try to keep this thread as up to date as I can.
Blue ion headlamps
Abs canards
Thin side moldings
Gloss black roof
ARP head studs
Skunk2 adj cam gear
Dsm 440cc injectors
Precision FMIC
Tial wastegate
Greddy RS BOV
Slim fan (modified)
EGR delete plate
Stage 2 comp clutch
An fuel fittings
Custom dump tube
Innovate wideband
Hkb steering hub
Oem black carpet
Oem eg door panels
Audio system delete
Shifter extension
Roll bar padding
CPillar bar (gold)
Powerslot rotors
Hawk hp+ brake pads
SS brake lines
230whp
230 tq
6 psi
