my newest eg project
cincy_ civic
BLOW EM UP
i had a nitroused 2000 SI i didnt really posted much about sold it to fund another build but went to the dark side BBBBB
Engine/Driveline:
B16 Head.
GSR cams
GSR cam gears
B20 Block
New barings, rings, oil pump from honda
ARP headstuds
Cosmetic head gasket w/ B20 vtec kit (dowel pins and Oil line)
Gates Racing Timing belt
NGK Spark plug wires
NGK Spark plugs
Cast Turbo manifold
GT1752 Turbo, Fresh Rebuild
^ Internal wastegated @ 7psi
Custom 2.5'' downpipe
Full 3'' Turbo back exhuast
Front mount intercooler
Real HKS SSQV blow off vavle
Precision 440cc fuel injectors
Walbro 255 fuel pump
Avid Torque mounts
Energy suspension solid Motor mount inserts
Stainless steel feed and oil return lines using Earl's AN fittings
Short throw double bend shifter
TPR catch can/Breather
Stage 2 Clutch with heavy duty pressure plate
GSR 5 speed transmission
12.5lb flywheel
P28 ECU w/2step
Dyno Tuned by Total Performance Racing in Fairfeild ohio.
Interior/exterior:
Newer Black paint job
JDM EG fenders w/ Sidemarkers
Amber Corners
Stock spoiler
Sunroof
Power windows
Power Locks
Clean Black interior
cincy_ civic
BLOW EM UP
OLD pics
cincy_ civic
BLOW EM UP
greg and go-autoworks is the shizzzzz
prepping for paint, hmmm purple maybe?? i dont know yet
cincy_ civic
BLOW EM UP
so LOTS of updates on her....
special thanks to dave for helping me out MASS on this thing!
cincy_ civic
BLOW EM UP
just a small update on the car recently..
I am installing a sleeved b16 block, cp pistons eagle rods next week, race gas and higher boost look out son
somejaykid
i'm a mod now
nice what numbers are you getting with your turbo?
H22Monster
im loving the rims. and do you have to remove the windshield washer fluid for the turbo or does it go just beside it?
cincy_ civic
BLOW EM UP
its not for the winshield washers its the over flow bottle for the radiator, the fmic kit is a full race kit from greg at go autoworks great product...
the turbo i have now is good to 500hp i believe so i will have to upgrade eventually
the block will hold 800+ hp its golden eagle HD sleeved...the guy i bought it off of is from st.louis he dropped a valve on his last setup chewed up on of the pistons but he had it checked out and held a leak down threw a new set of rings on it and was good to go, i got it for a steal so couldnt pass it up...
I'm buying a set of springs and retainers and a victorX intake mani and thats it for now ill run that setup with this turbo for the fall
over the winter im going to save up for a gt42r and a nice ram horn or top mount mani
I <3 rice
Awesome job man! Correct me if Im wrong but I thought at one point I saw this car for sale on craiglist a while back.
cincy_ civic
BLOW EM UP
yes i had it fs for awhile with the current setup on it but i wasnt letting it go for nothing so decided to keep and am going to shoot for 600+hp
ImportFan1
Super Moderator
Pics of the new s**t you got this weekend?
