im almost finished with my set up. i have everything done exept the fuel. im runing way lean. what do i need to finish my set up. i have a 3.6 lb spring and want t run 6 PSI. will that work? wht do i need for electric work and fuel mangment. thanks
Get a boost controller, And make sure you have a boost gauge hooked up.im almost finished with my set up. i have everything done exept the fuel. im runing way lean. what do i need to finish my set up. i have a 3.6 lb spring and want t run 6 PSI. will that work? wht do i need for electric work and fuel mangment. thanks
It will plug in and should run ok, but it's still just a basemap. After you install it you will still need a full tune.if i order it from herehttp ://www.phearable.net/products.html and tell them what i have will it plug right in and work
That all depends on if his car is obd1 already. If its obd2 you'll need the proper conversion harness.It will plug in and should run ok.
what exactly have you done. ?im almost finished with my set up. i have everything done exept the fuel. im runing way lean. what do i need to finish my set up. i have a 3.6 lb spring and want t run 6 PSI. will that work? wht do i need for electric work and fuel mangment. thanks
What parts did you collect?
How do you know you are running way lean?
