I just finally put in a VTEC indicator light in my car following www.hazone.com for the ECU hook up, and a gauge cluster install from somewhere else to put the light in my cluster.
Hazone has one error... or it didn't match (even though I have a 6th gen EX). According to the Helms manual, the VTEC solenoid wire is the green with yellow stripe wire on connector A1 (gray) at pin 8. Hazone said this connector was the "2nd near to you connector". This is not true. For me, it was the 3rd (gray) farthest from me connector. The green/yellow wire was exactly where Helms said it was.
Be CAREFUL when cutting the electrical tape binding your wires together. Use a sharp blade and slowly split the tape open. I almost severed an unrelated wire.
I bought a RadioShack blue 5mm 30mA 560 IL LED with a 390 ohm resistor (which by my calc is about 30mA)... and it's still REALLY dim. Plus, it's a b***h to mount the sucker right. I used some 5/16" air/fuel rubber tubing and jammed it in the light well to hold the LED in place. I shoulda glued it in there because somehow it's aiming to the side.
VTEC on my stock D16Y8 kicks in around 5500 rpm. That seems a bit useless to me since redline is 7000 rpm.
