brianseg
Okay so as some of you may know,I had purchased a 94 honda civic ex d16z6 5sp.Orginal owner thought the head gasket had blew yea that story.So after rebuilding the head up couldnt get the car running.I replaced the distributer,distributer cap ,rotor,spark plugs and wires,fuel pump,fuel filter,coolant temp sensor,injectors,computer and relay,after doing all this work spending hundreds of dollars on replacing everything. Some of you thought my timing was off it wasnt.The car was getting spark,and fuel.Could not for the life of me find out why this car wasn't running,everything seem to be working.I had to take it up to my mechanic and it all came down to a resistor as they called it, caused my computer not to work properly they fixed it cost me about 100 dollars to fix.Now this wasnt a bad computer the way my mechanic explained it to me there was a resistor or fuse what ever one want to call it in the (wiring) not the fuse box that was causing my computer not to get power during cranking.dont know what this part is called but if anybody needs to know more detail.I'll call my mechanic and get more info.But the Car started right up and runs great now thanks to everybody who tryed to help me with the problem hope this may help sombody out
