98 Civic EX. A/C not always blowing cold enough. Spent a couple hours messing with it and another couple searching online for this problem to no avail.
The issue is the OPPOSITE of most A/C issues. Most people can't get the A/C clutch to come ON. I can't get mine to shut OFF. It is on constantly at idle - which is dragging the motor down and making it get hot. It will cycle off briefly when you press accelerator but then it comes back on and runs constantly until you drop motor back to idle and then gas it again. Put gauges on it - low pressure at idle hangs around 40 and high at around 210. 97 degrees outside. When you rev it up to about 3k rpms the low pressure will go up to about 80 and high to around 300 but clutch stays on. Condenser fan and radiator fan work fine. Blows cold air most of the time but not always - which is ok but due to the lack of power this little motor has, the A/C compressor being on all the time just KILLS the car. I have kind of a intermittent flutter at cruise speed like it's missing but no CEL. Just feels like a miss and no power because the A/C clutch is on constantly. It didn't use to be that way - used to feel the car drag down as it cycled?
I changed distributor recently, and reset timing by the book. At least I think so. Put timing light at a slight angle toward back of motor in order to see v notch and marks and set it on middle of the 3 marks?? With the connector inside passenger kick panel jumped and CEL on as it is supposed to be to set it.
SO - any ideas from the A/C experts?
