Need Ac help?
ku_yugioh
I need to change the ac expansion valve because my ac isn't working. The compressor works fine and there is absolutely no leak but the expansion valve won't open so I can't get any ac. I know that it located under the glove box but do I have to remove the whole plastic box or get to it b/c I can see it when I remove the plastic cover but it only 2 inch wide so I can't work on it. Thanks in advance and detail on bolts that need to be removed would be helpful.
ohsnapzitzmeng
how do you know its the expansion valve? is it not cooling? is the ac clutch not catching?
