Need help for AEM cold air on 6th gen EX
BL96EX
Hey guys I just installed an AEM on my 96 EX and Im sort of confused on one part. If anyone knows what the air control valve vacuum line is and where to/from it should be moved I'd appreciate the help. Everything else went smooth so I will post a complete how to once this is done.:???:
DirtyD
are you talking about the line from your valve cover to the intake? or the throttle body coolant hose? or the sensor on your intake?
BL96EX
The breather hose and and the IAT sensor were on the stock inlet tube and i transfered them fine. Theres another nipple on the AEM tube where the instructions say you should connect the "fuel injection air control valve vacuum line" . I have no idea which line they're talking about or where it is.
illicon2003
master pimp
pretty sure it's just the tube running from the air intake to the short block........Let me see if I can find a picture..
can't find one but it's a metal tube like a straw that you drink out of..bonded to a little tube..plug that into the left hole on intake..air intake temperature sensor plugs on the right hole I believe. lates
