need help on figureing what else i need
civic hatch
ok ive been reading up on turbo and how they work form the last 6 months now and i have gotten some great info, so now to the question.
i building my own kit and i real syked about this, my list is
things i have
garrett t25 (new)
HF mani with adaptor plate
down pipe that i welded my self (no leaks)
oil lines
turbo XS blow off valve.
greddy E-manage
things i need
intercooler and piping
what else am i missing
also would i be safe for now only to run 6lbs on stock injectors with the E-manage.
i have more e-manage question but i need to do more reading on that first
thanks in advance
rickles8099
Faster than you
for the intercooler go to johnnyracecar.com for a nice intercooler.
for piping, i used some radiator hoses (from junkyard) pieced together with 2" exhaust piping along with a cold air intake from ebay. my not be pretty, but is cheap and gets the job done.
bizoneoeh
Ex-Gang Member
civic hatch said:
things i need
thanks in advance
I say you might want to get a boost gauge and maybe an oil pressure gauge, well that's what I have at least.
I say get some bigger injectors, I'm using toyota 310's myself @ 8lbs. A friend of mine kept his stock injectors and it ran like crap on 6-8lbs. I just had my piping made for me and I'm using a dsm side mount ic. I actually needed only 1 pipe made, the charge pie that goes into my intake mani. the other pipe that goes over the turbo is off the same dsm
this is a pic of my set up right after I got it. I've had a new bigger charge pipe made for me since then and different wires.
I'm not sure if I have a dsm, supra or a nissan side mount intercooler. I originally had a dsm side mount ic but my boy threw this one in because it fit better.
civic hatch
so my new list will be
intercooler
piping
bigger injectors
guages (oil, boost)
now the question is can i hold off on the injectors for now untill more $$$ roll in. and will the E-manage control them (injector cycle wise) for me
bizoneoeh
Ex-Gang Member
I say yeah, run low boost around 4lbs but make sure you get your car tuned. If you don't get your s**t tuned then you won't have to worry about getting bigger injectors later, you'll be worrying about finding a new motor
rickles8099
Faster than you
just buy some dsm 450s off of ebay. you can usually get them for around $70 - $80 shipped. also if you run low boost now with stock injectors, you will pay now to get it tuned and then pay again to retune it when you get bigger injectors.
edhgreatone
haha i saw this same post on turbod16 but anyway yeah i'm in the same boat as you
Inigo Montoya
powered by boost
you need vaccuum and oil lines as well as couplers and t-bars (12). also need oil fittings.
