need help quickly: installing sub system
TippinOver
reppin the 2StockCrew
hi all
well, i finally decided to install a system in my car...
i'm having trouble getting the amp to turn on..
i've got the power to the battery, the remote and rca's ran and connected, and the ground too...
when i turn the ignition on, the amp light cuts on, then right back back off in a second...no amp...
i checked the ground and when i move it on metal, it sparks, meaning a current of power is made...
should i do a better ground?
any help?
thanks!
that VERBAL
AKA Theiven Stealberg
double check the connection on your remote wire
io_303
NIFOC
that sounds like a remote wire problem, check it with a multi meter
1999stockaccord
Honduh's... LULZ
:werd: sounds like the remote wire is shorting out, make sure it didnt get pinched or anything during installation
I saw the same thing happen in my boy's eclpise, we found it had gotten pinched under the door sill AFTER we had redone all the other wires and still had a problem, lol
$lick Rick
TEOTWAWKI
what kind of amp?
K2_civic
Fo-drizzle!!!
sound like you've got a short in the amp, if its not the remote wire, you need to use a volt meter to test all the connections for the right voltages and if thats not it, test whats going to the speaker, could also be a loss fuse in the amp, what all are you installing?
TippinOver
EDIT: got it working
my ground wasnt good enough. it was good enough to flow a current but not turn the amp on all the way.
found a new ground, everything sounds good,
i'll make a new post soon shoing off my new "trunk"
thanks all!
