Arty33
Hello everyone, just had a rear disc swap done at the mechanics. Issue i have is the pedal goes down pretty far, for it to stop, said he bleed the brakes, i know he didn’t install the proportioning valve from the doner hatch, and the main issue is if i take the car for a ride longer then 25 minutes, the front passenger side rotor is hot that it literally has some smoke coming from the rim, the rim is hot that you cant even touch it. And the other 3 rotors are like a greyish color and the passenger front rotor is like chrome where the pads meet the rotor. It has the factory master cylinder it had when it was drum brakes, i been reading all different posts about rear disc setups, and i’m not sure what the issue is. I cant even drive the car, dont wanna do any more damage. Bought the rear disc setup out of a 95 hatch, not sure what it originally came out of. Brand new rotors front and rear, new pads in rear, new flex hose’s in rear. So not sure why the front passenger gets redhot and not the other 3. No issues with the front brake setup when the drums were in the rear. Car also has integra brake setup in front, was installed when i bought the car 2 years ago, i need your help please. I think it has something to do with the proportioning valve, but i don’t know, thank you all for your help
