soufigured
Hello, I'm in need of some help. I have a 93 civic si (d16z6) and I'm having some trouble diagnosing my problem(s). So to start off I've had my civic for just about a year and over the last couple months I've noticed it using a lot more fuel, very rich exauhst, lackluster performance. Since the day I got it the rpm goes up to around 2000 at start up and then drops down to normal once its warmed up witch may just be because its a 22 year old motor with over 420000 km (about 260000 miles) or it could be a clue to my problem. I've since replaced my air filter, fuel filter, manifold o2 sensor, cap, rotor, coil, plugs, and wires. Now at start up it still idles high till its warm but for the first couple seconds there is a fresh gas smell, it still uses too much fuel and has no power most of the time but sometimes it seems to run just right and just tonight I noticed an air sucking type noise from the engine bay near the air filter but it isn't the airfilter itself, it seems to be coming from further towards the rear and lower down. This leads me to think vacuume leak, or maybe fuel pressure regulator, or the pump. But I'm not the most experianced. Also no check engine light and it does work. I'm sorry if I've been all over the place I'm just trying to describe as much as I can. Other than the aforementioned symptoms it runs great, no stalls, idle is stable, goes smoothly from a warm idle (that very first mark above 0) to 7000. So I hope I've given enough info. Thanks in advance for any help
