Need Help With EBC
Redsi15
Hey fellas, This might be a dumb question but i am having trouble figuring out how to setup up my greddy profec spec b 2 boost controller. I have a -00 civic si, I have my boost gauge t fitted at the fuel pressure regulator. So i am trying to figure out how to hook my mvs wastegate up along with my bov and boost controller to a vacuum source. I know wastegate has hose going into boost solenoid then coming out from other side of solenoid i was going to run hose to T fitting that would also have the 4mm hose coming from the actual boost controller from inside the cabin. The boost source that i was going to use for that setup was from the cruise control vacuum line from back of the intake manifold.
With all that being said and hopefully not confusing. Where do i get the vacuum source for the bov? Also am i setting everything up correctly? This is my first time boosting a car and i am just trying to make sure i run everything right..
Good feedback will def be appreciated
Thanks in advance
2slo4u
wait4me
might be easier to use a vacuum manifold
DarkCreep
D16Y8+T
Have you tried using the spot behind the intake manifold for the cruise control? Thats a great spot for a BOV or boost controller.
