Well your Hatch might be a 96 but you sourced your power conversion off a 99 Civic, which is why its not working. There is a difference between the 96-98 and the 99-00 Harnesses, they are not interchangeable. I bet you're throwing an CEL Code for a Circuit Problem with that 99-00 Floor Harness on your 1996 Hatch.my hatch is a 96 lol i'm wondering why you're talking about 99-00 but i don't think i have that blue box though... soooo if i were to get that blue box i should get it from the 99 civic or just from any random civic?
The power door lock reciever is in the radio unit on a 96-98. You will not get things to work if you use the 99-00 floor harness. 96-98 civics need the stock radio wired for the power door locks and usually tuck it behind the dash if they want to use an aftermarket head unit.Well your Hatch might be a 96 but you sourced your power conversion off a 99 Civic, which is why its not working. There is a difference between the 96-98 and the 99-00 Harnesses, they are not interchangeable. I bet you're throwing an CEL Code for a Circuit Problem with that 99-00 Floor Harness on your 1996 Hatch.
You should've gotten a 96-98 EX Floor Harness & 96-98 EX Door Harnesses for your 1996 Hatch to do this properly. Then the other parts could've been off any 96-00 Civic EX.
You cannot get the Blue Box and connect it to the 99 Harness you have because it wont plug into it. You need to get the Power Lock Control Box from a 99-00 EX, its behind the Driver Side Kick Panel and then while you're at it, check to see if it connects to the Floor Harness or to the Dash Harness. If it connects to the Floor Harness, then you're good just get the box and connect it. However, if it connects to the Dash Harness you will need to remove it as well and swap it out if you want to have Power Locks.
so the power lock control box is suppose to be installed where that is in the picture there? i don't have it i just checked... so i'd have to get it from the 99 and install it at that spot?Like I said, I have no idea if its in the same location in the 99-00 Civics as in the 96-98 Civics, I know somethings change within the years for the Power Window/Lock/Mirror Conversion. Anyways, here is a picture of where it is located in the Driver Side Harness for the 96-98 Civics, its the Blue Box you see there to the upper right:
EDIT:
After doing some light searching I read up that on the 99-00 Civics, the Power Lock Control Box is located behind the Driver Side Kick Panel. So make sure that you have that box there. Also, I believe that it plugs into the Dash Harness and not the Floor or Door Harness on the 99-00 Civics, so if that's the case you will have to pick up the Dash Harness and swap that as well in order to have the Power Locks working on your 99-00 Civic. If I were you though, I would do a little more research to confirm this though.
Technically yes, because your car is a 96-98. However, its is not the case in your situation because you used a 99-00 Floor Harness and 99-00 Door Harnesses, you are suppose to use the Harnesses off a 96-98 EX when doing the Power Conversion on a 96-98 Civic, same applies for a 99-00 Civic you are suppose to use 99-00 EX Harnesses. The 99-00 Harnesses you are using have the Power Lock Control Box located behind the Driver Side Kick Panel and connect to the Dash Harness.so the power lock control box is suppose to be installed where that is in the picture there? i don't have it i just checked... so i'd have to get it from the 99 and install it at that spot?
Okay sweet, but now to identify the Door Harness and Floor Harness; like my power windows and everything are connected and working. Anyone got a pic of where the floor harness is located?^ Is yours a 96-98? If so, just make sure that the passenger side Door Harness is hooked up to the Floor Harness. Also make sure that the Passenger Side Power Lock Actuator has the Plug connected to it. That's all you have to do. You dont need to connect it to the Blue Box, the wires are already there and run through the Floor & Door Harness to it.
Floor Harness is underneath your Carpet. The Door Harness is behind your Door Panel. Remove your Passenger Side Door Panel and make sure that your Power Lock Actuator is connected to the Harness via the appropriate plug.Okay sweet, but now to identify the Door Harness and Floor Harness; like my power windows and everything are connected and working. Anyone got a pic of where the floor harness is located?
You should really make a new thread about your issue, rather than bumping a 2 year old thread. You're new, so just letting you know for future reference.hey guys i have a 2000 Honda civic ex 2 door but the car was stolen so they took everything that has to do with power window and power lock so now I'm trying to put the power windows and the power locks back in the car again. so this is what i got so far i got the diver side window wiring harness from 1998 Honda civic ex 4 door but my question is that i don't know if that will work with my 2000 civic ex and also the car is missing wiring harness that go to the passenger side door from the dash but i don't know how wiring harness look like and have no idea how it go in the car so if you guys can help me that would be awesome
