Need help with swap
CivTegraHB
I have a 93 HB with a b18c6 with a 5 lug conversion. I want to swap the b18 w/ the 5 lug into my 97 CX HB and my question is what can I salvage from the EG and use in the EK. The EK has the stock dseries engine in it. Can I use the same wiring harness, axles, shift linkage, and mounts from the EG in the EK and if not what parts do I need to make it work. I'm also thinking about keeping the A/C in the EK.
Jersey8
B20: Detroit Muscle!
you can use the same wiring harness but you will need to wire up vtec.
you will need B series axles, shift linkage
you can use the d series mounts, except you might need a drivers side mount from a gsr (all b18c's have a 3-post driver side mount, all other b series have a 2-post)
you will also need a 99-00 SI rear trans bracket (bolts from trans to rear mount)
there is already a ton of info on this all over the internet...
http://www.superhonda.com/forum/f49/6th-gen-civic-b-series-swap-info-286159/
http://technet.ff-squad.com/
