Need help with these hoses!! *** WITH PICS***
EK_99_BOI
Ok i need to find out where these few hoses hook up to. The engine your looking at is a D16y8 so if anyone could look on there cars for me to locate where these hoses hook to i would appreciate it.
I need to find these connections (red arrows pointing to them)
And heres that same picture at a different angle..
This is a fuel line arrowed in blue.. i need to know where that is connected to
The same picture at another angle..
All help is needed!!
Thanks
MasterShake
i know the fpr goes to the IM....
12.8:1 Ls/vtec
IT'S OVER NINE THOUSAND!!
That blue arrow hose is the fuel return line that goes to the large side of the fuel pressure regulator. the large vacuum port on the front of the intake manifold is where the hose to the crankcase ventilation hose goes. The vacuum port on the intake manifold right next to the valve cover is the air injection port(only on 99-00 motors) plug it if running a 92-98 ecu. Don't be surprised if the fuel return line is not gonna fit b/c there should be a metal hose that runs across the bottom of th fuel line which you may need to get that piece or join together some more hose and some clamps with a joint piece. I don't know where the purge cut solenoid valve goes to but I remember it having a long hose attatched to that end so look about 1 foot for an open port.
EK_99_BOI
Thank you very very much.. i will go connect those asap!!
:thumbup::thumbup:
john92civlx
budget builder :)
dude allways knows his s**t
12.8:1 Ls/vtec
I used to have a d16y8 as well in my 5th gen but semi built. If you need some d series info just ask. I bought a 6th gen ex to salvage the motor out of to put it in mine. Good luck:cool:
