need opinions plz im completly lost
bzimmerman
I have a 1989 Honda civic hatch. It's all stock. My friend was driving it and the car just died on him in middle of the road. I looked at it and cylinders 2 3&4 had oil in them. I ran compression.check and all cylinders hit about 125psi. I checked my spark and it was good. I have fuel in all cylinders you can smell the gas when you take the plugs out. The timing is still in. I have no clue where to go with this. Some one suggested maybe a headgasket? Any opinions? Anyone plz
95CTR
52mpg? I do it all day.
i have NO idea, but it might be worth it to do a leak down test, and see what readings you get from that
Billy.
Has returned ;-)
The oil in the cylinders is probably helping to hold cylinder pressure during your compression test. If it's not coming from the headgasket, maybe bad spark plug boot seals :what:
95CTR
i dont think spark plug boot seals would do it because tehy dont lead into teh cylinder, they only lead to teh spark plug, which would fill the tube up......right?
Avant Uprising
GONE FISHIN
Ive seen them leak so bad they get pass the threading on the plugs and leak into the cylinder
Sent from my LS670 using Tapatalk
Billy.
Has returned ;-)
If the oil sits in the boot long enough it could eat its way through to the cylinder
crash!
Avi, pull your socks up.
If the oil is milky that would be a good sign of a headgasket.
And I agree with Billy saying that the oil in the cylinders are sustaining the psi in the compression test, that's essentially what a "wet" compression test is to see if the rings are truly bad.
I agree a leakdown test is in order.
bzimmerman
Thanks for all the help guys. For a leak down test do I just turn the motor over by hand till it hits compression on my tester guage and just leave it there for a few minutes?
DuckIt
To do a leakdown test, you fill the cylinders with compressed air, to pinpoint your leak then.
