Need some help
Sirk
i need to test the resistance of a resistor that works with my turbo kit.
i had to cut the wire that goes to the vtec solenoid so it now goes to my piggyback ecu.
where the it used to join to the ecu plug i had to put a resistor in.
it may be faulty so i need to messure its resistance.
will i need to cut the wire before or after the resistor to messure it or can i do it from the plug side of it??
here a pic if i've confused you black thing with green wire is resistor
