Want me to scan the list of what the bar ref had as a 95 ka requirements?
I might still have the info.
The 95 ka i had was obd1..... the early ones were. He wanted obd2 compliant because thats what his list had it as (per the number on my ecu), so it basically fell under the 96+ requirements
Stock 510 tank isnt pressurized, doesnt have evap. So i couldnt just run the tank stuff, i would have had to change the tank.
Carb compliant short ram intakes still go forward too far. My waterpump pulley was touching my elec fan on my radiator, there was no way i could follow the route of the stock air tube and go across the motor to the drivers side.
I had to relocate the o2 sensor on the stock manifold. This was an issue as well. Stock o2 output is right in way of steering box. No way around that.
I was big in the 510 scene, and it is pretty close knit community so when i brought all this up on the forums, im sure i would have known of any others. I know there are alot of people that are not on the internet, but they are in other places.
So it was a mix of mis information that the ref had, and the fact that it was a waste of my time to do all that.
here is list of what ref wanted.
pcv, evap, twc, fr, bp/egr, spl, h 02s's, cec, mil, evap-vc, evap-cs, bp/egr-cs, bp/egr-ts, spk-cc.
So thats 2 02 sensors. I have the list that he has for s-13 ka as well.
He had listed on checklist page.
"install two oem heated oxygen sensors to oem configuration for 1995 Nissan 240sx 2.4l"
I was going to switch my motor to make it an s13, I had everything i needed But the PAIR valve off the exhaust will not fit with stock 510 steering. Also i would have had to grab an s13 harness because i needed wiring for flapper valves in intake.
