Just realized I forgot to post whats done to it lol. Heres a list of random things done to the car.
K&N filter
Skunk2 70mm TB.
Blox TPS sensor.
Chipped p28 ecu with flashtune for the setup. Launch control and 8300rpm redline.
2000 SI rear bumper
2000 SI front seats
2000 SI gauge cluster
2000 SI front clip conversion
2000 SI clutch and brake master cylinders /w proportioning valve
NRG innovations oem carbon fiber hood
brand new oem side mirrors
Nippon racing polished 6 spoke 15" wheels
Toyo Proxes R888 205/50s(less than 5000 miles)
Lotek shorty series struts, Lotek adjustable spring rated coils.
GSR complete brake swap, on FULL energy suspension master rebush kit.
GSR rear swaybar
GSR front strut bar
GSR full core radiator swap
GSR hid harness/ballasts
GSR oil pump
GSR water pump
GSR timing belt
GSR p72 ecu
GSR td-84u dizzy
JDM 55k mile B20B block
OEM rebuilt GSR p72 head
ACL race series bearings
Magnafluxed/polished/shotpeened/compressed/balanced PR4 rods, drilled with larger ARP rod bolts
RS machine 84MM 12:1 GSR replica pistons
SUPERTECH blockgaurd
ARP headstuds
ZERG thermal intake manifold gasket
ATI street damper
NGK 1-step colder plugs
GOLDEN EAGLE vtec conversion kit
BLOX version3 intake
BLOX cam seal
RYWIRE subharness
4-1 longtube header /w 2.5" collector into 2.5" highflow cat and catback /w OBX FORZA style oval muffler custom crankcase-exhaust evacuation
B&M Fuel pressure regulator
SIDD fuel pressure gauge
b16 SI trans(4.4 final drive) /w synchrotech 3/4 synchros
DriveShaftShop axles
Fidanza 7.5lb flywheel
6 puck clutch
INNOVATE LC-1 wideband a/f gauge
OMNI POWER knock sensor
All oem honda gaskets
All accessories in engine bay removed
