My name is drew and i drive a 97 civic
and this is how it looked before the new paint
Engine:
JDM GSR shortblock (b18c)
Approx 11.8:1 compression
B16 pistons
New rings
New bearings
New thrust washers
ARP headstuds
Cometic headgasket
New oil pump and tensioner
P28 ECU. Socketed with Kenji ITR program.
B16 second gen head.
Omni Flat faced valves
Omni dual valve springs
Omni retainers
Blox intake manifold
ITR injectors
JDM ITR red valve cover
B16 cams
JDM DC Sports header w/ 2.5" collector
JDM Omni test pipe
Apex'i World Sport 2 cat back exhaust
AEM CAI
AEM TRU time pulleys
OBX Underdrive pulley
Transmission:
JDM B16 hydrolic 5-speed transmission
ACT clutch
Clutchmasters flywheel
New axles
B&M short shifter
Energy Suspension urethayne shifter bushings
Exterior:
Black Tails
Projector Headlights
8000K HID Kit
Si Grille
M3 style mirrors
Supension/Braking:
Arospeed coilovers
Tokico shocks and struts
Slotted and drilled front rotors (not sure what brand)
Rear strut bar
Rear lower tie bar
Audio/Electronics:
Blaupunkt Bahamas head unit
Blaupunkt PCxb652 front speakers
Clifford alarm/Keyless entry
before spring hits i hope to throw some cams in
Engine:
B16 pistons
New rings
New bearings
New thrust washers
ARP headstuds
Cometic headgasket
Omni retainers
ITR injectors
B16 cams
JDM Omni test pipe
AEM CAI
Transmission:
ACT clutch
New axles
B&M short shifter
Exterior:
Black Tails
8000K HID Kit
Si Grille
M3 style mirrors
Supension/Braking:
Arospeed coilovers
Rear strut bar
Rear lower tie bar
Audio/Electronics:
