CaptainJochem
Hey all,
I recently swapped my engine for a B16 and in the process replaced the leaky head gasket with a new one. Had a few problems with starting the car, but that's all over now and I'm able to drive it around; perfect, well, almost. I noticed that my exhaust gases were slightly whiter than usual and after testing the cooling system with a simple test the dye came out yellow which means I have exhaust gases coming into the cooling system; a leaking head gasket.
What I am curious about is why this could happen? I did install everything properly (to my knowledge), new head gasket, new cylinder head bolts, smoothened the cylinder head and checked the block. I torqued everything down as per the manual. I was thinking that maybe the dowel pins needed to be shaved off a little bit too since I didn't do that. Maybe this is causing a little leak?
Would it be smart in this case to make the bolts a little tighter? Just want your guys' opinions, much appreciated!
Jochem
Jochem
